TwinTurbo.NET: Nissan 300ZX forum - Re: 1991 300ZX Timing/CAS/TPS Help Please
oninous
on February 23, 2011 at 9:27 PM
posted by oninous
on February 23, 2011 at 08:33 PM
Where I said re-connected the CAS I meant I re-connected the TPS. The car won't run with the CAS unplugged.
oninous
20:33:57 02/23/11
Re: 1991 300ZX Timing/CAS/TPS Help Please -
oninous
21:27:49 02/23/11
You need to mark the location of the CAS and also
KongZTT GT28RS MD
22:11:41 02/23/11
Re: You need to mark the location of the CAS and also
oninous
03:37:42 02/24/11
yes.. did you use the loop thing on the EFI harness?
KongZTT GT28RS MD
08:47:20 02/24/11
Re: yes.. did you use the loop thing on the EFI harness?
oninous
23:16:05 02/24/11
The cas has 3 bolts to loosen , 1 is hard to see on
xteam300tt
10:58:45 02/24/11
Re: The cas has 3 bolts to loosen , 1 is hard to see on
oninous
23:15:11 02/24/11
Why are you checking the timing ?
xteam300tt
11:11:43 02/24/11
Re: Why are you checking the timing ?
oninous
23:14:01 02/24/11
